KingRex PSU MKii - $419.00 USD - Moon Audio is the U.S. distributor for KingRex Products.
May 3, 2013 at 12:05 PM Thread Starter Post #1 of 1
Description
The Kingrex PSU MKii power supply unit is available in a Variety of output voltages. Such as 12V, 9V, 7.5V, 5V. The
7.5v for use with the KingRex UD384 and & UC384. Other versions can be special ordered.
The 5V version can power the Calyx DAC 24/192, Squeezebox Touch, Onkyo ND-S1 iPod Transport, and the RAL-
1648iP1 iPod Digital Data Converter, etc.
The 9V version would power a Squeezebox receiver Squeezebox Classic/Duet, M2Tech EVO (7~11V)
The 13V version can power the KingRex T20U, Acoustic Revive RR-77, Nuforce icon, Wadia 170i /171i, TC Electronic
Konnekt, 8 Nuforce icon II, Chordette Toucan, Squeeze box boom, ECHO AUDIOFIRE,4 Nuforce HDP, My audio X-02,
Cambridge DAC magic, Simaudio Moon 110 LP and Musical Fidelity Vdac mk2 DAC
Inside the PSU Mk2 there's a 48VA toroidal transformer, a regulated power-stabilizing circuit with 8 capacitors, 5 x
2200μF at AC input stage and 3 x 4700uF at DC outputstage. 6N Furukawa PCOCC wiring through out. The unit has a
3 pin Neutrik DC connection on the PSU side to DC jack (electronic side). The included DC jack is a5mm external, 2mm
internal type
The switching power adaptor is the most convenient and common power source however it is not a good selection for
the music connoisseur who prefers sonic performance over convenience as it has the most noise and distribution due
to the high-frequency switching and harmonics in its design. The linear power supply is a better choice for audiophiles.
It has less noise and distortion than the switching power adaptor, however, during the AC to DC conversion and
rectification process, there is still minute amounts of unavoidable noise and distortion. That’s because the AC power is
required to traverse significant circuitry such as transformer, diodes, voltage regulators, and other components.
Specifications
Transformer 48VA totoidal type
Voltage regulatory circuit 5x2200uF at AC input stage
3x4700uF atDC output stage
Input rating Factory set toAC 50/60Hz 100-120V or 200-240V
Output rating 5V /7.5V / 9V / 12V 3A
Output rating 15V/18V 2.5A
Output rating 24V/1.5A
Measurement 185x138x45mm
Thank You.
Drew Baird, P.E.
Moon Audio
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/ https://www.youtube.com/@moon-audio sales@moon-audio.com
