CrawlingEye
- May 12, 2003
I read on Riovolution's forums that using ogg will decrease battery life most over all other filetypes. All my songs are currently encoded in Quality 8 ogg's and after trying to run my battery down completely (I read also that you'll maximize your battery by running it down completely shortly after you've purchased it... the rate was a 4% less of a decrease in battery life a year), the battery would just simply not die. I use minor EQing (1dB bump at 40Hz with a Q of 4) and was on a volume of about 15-20.
My battery simply would not die. I started around 12pm-1pm (not exactly sure) and around 9-10pm it wasn't even down to quarter of a battery so I gave up and concluded that my battery life was at its maximum. I believe it would've gone past midnight to drain the charge completely.
Definite thumbs up on this!
