[KA3/KA13] FIIO X JADEAUDIO USB DAC DONGLE
Sep 18, 2023 at 1:09 PM Post #601 of 899
Wow, that's truly a powerhouse.
Sep 18, 2023 at 8:48 PM Post #602 of 899
FIIO Mini Desktop Headphone Amplifier KA13 Is Officially Released!​
After nearly two years under fine polishing of FIIO engineers, the KA3 has been upgraded to the KA13 as a mini desktop-class DAC and headphone amplifier. It combines new design language, new technology, and robust performance, configurations and experience in one. We focus on creating a more omnipotent and comprehensive USB dongle that can provide users with a full range of high-quality experiences.
Mini desktop amp, big performance
USB dongles are characterized by their small size and small output power, but the KA13 is bound to break the rules and achieve a breakthrough in power in a small space. It adopts the “Desktop Mode” which was generally seen in our high-end products to achieve robust performance nearly equal to a desktop device, and make the KA13 come with the highest output power among USB dongles.
With the “Desktop Mode” on, the maximum sustained undistorted output power of the balanced port goes up to 550mW per channel, which is nearly equal to a desktop device, so that it can drive most headphones, allowing you to enjoy quality music in both portable and desktop use scenarios.
Comprehensive configurations, full of sincerity
Listening experience is subjective, but the configuration can be truly seen, and is the basis of a good sound. We chose a better configuration for the KA13 in USB dongles at the same price range -- dual high-performance low-power consumption DAC chip CS4313 + dual low-noise op-amp chip SGM8262. The dual-core golden combo features excellent performance and indicators with superior resolution. With support for 32bit/384kHz PCM and DSD256, the KA13 despite its tiny size is capable of highly-detailed sound.
Excellent user experience seen in details
In addition to high output power and configurations, we also attach great importance to user experience. Being carefully crafted, the KA13 is outstanding in all aspects. Here are the details.
* A family aggressive mech design gives it a new look; the RGB ambient light window also shows corresponding sampling rates - a unique beauty of technology and aesthetics;
* 3.5+4.4 dual headphone outputs: FIIO engineers repeatedly adjusted the design of the KA13 and finally managed to fit two headphone outputs in the compact dongle, marking true progress in packaging capabilities.
* Features a detachable cable design. When combined with the included Type-C and Lightning adapter cables, you can listen with various systems without having to immediately purchase another cable;
* Supports being controlled with the FIIO Control app. With the app, you can set the RGB lights, SPDIF output, audio filters, etc. for a more convenient experience.
Promo for early adopters
(1) Time: From September 18 to 20
(2) Offer price: 75.99 USD (5% off)
(3) Place: https://www.aliexpress.us/item/3256805865925636.html
Thank you so much for your attention. If you have any questions, please feel free to reach us out!
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
Sep 19, 2023 at 3:07 AM Post #603 of 899
Best regards,
@FiiO why is there a toggle for desktop mode? Is this due to battery drainage if left on? Also would a usb cable with pass-through charging help with desktop mode?
Sep 19, 2023 at 4:52 AM Post #604 of 899
Balanced port: L+R≥550mW+550mW(32Ω/THD+N<1%)
Wow, that's a very high gain. Excited to get one for myself!
Sep 19, 2023 at 10:38 PM Post #605 of 899
Dear friend,
When the desktop mode is on, the output power and gain of KA13 could be higher.It is recommended to drive high-impedance headphones or the device which is hard to be driven. When the desktop mode is off, the KA13 is used for daily music enjoying and driving the low-impedance headphones.
And I am not quite familar with the pass-through USB cable you mentioned. Theoretically, the USB OTG cable could work with the KA13.
Best regards
Sep 22, 2023 at 11:30 AM Post #610 of 899
@FiiO Dear manufacturer, does KA13 has independant volume adjustment?
Sep 25, 2023 at 2:51 AM Post #612 of 899
Hi FiiO, can you share any info about what looks to be a Jade Audio open-back headphone in the above photo?
Dear friend,
I could only tell you that its name is JT1.
Best regards
Sep 25, 2023 at 2:52 AM Post #614 of 899
Sep 25, 2023 at 2:58 AM Post #615 of 899
@FiiO a review mentioned that the cable that came with the dongle is of different quality. Will any high quality USB-C cable work or is there a different spec for your cable?
https://www.techgoing.com/fiio-ka13-portable-dac-amp-review-big-upgrade-of-ka3/
As long as it is a low loss lightning cable is fine
If it is a low-loss lightning wire, it is possible
