oystercatcher
What phone are using?
The KA3 will not bypass Android SRC.
POCO F3. Running Android 12.
The chance is that it passes everything as 16/44.1.POCO F3. Running Android 12.
Dear friend,I encountered weird issue with Fiio KA3 on Samsung S20 FE.
I was on a walk. I had the phone and KA3 in my pocket. Every 1 to 2 songs, audio will cut out; just static and buzzing in the earphones. So I held on to the phone in my hands while I walked, and everything seems fine. Once I put the phone into my pocket, issue occurs. Couple times, issue occurred immediately within seconds after placing devices in my pocket. Other times, it happens in 5-10 minutes. I rebooted my phone, but issue continued.
The only thing I can think of is static electricity. Previously when I use KA3 while walking, I'm wore t-shirt and shorts (typically cotton). Now the weather is getting colder. So I had on a fleece sweatshirt, which can generic static electricity as I'm walking.
Since then, I have used the KA3 in 2 different environment, at home and at work. In both cases, I'm not walking and I just lay the phone and KA3 on the desk. No issues.
I will have to check when I go on walk next time with fleece or polyester clothing.
hello. i had the same exact issue (sound fading) with installed KA3 drivers on windows 10. then i installed the firmware 2.0 thinking it would help to resolve the problem. but instead it got worse: now i hear pops (when switching the tracks or youtube videos) AND sound fading is still the same. what should i do?When I do the sound test in windows sometimes the first sound fades in and the second sound is played normally. There has to be an option to have constant streaming. Some notification sounds are so short they don't even turn on KA3 (or whatever happens to it that it doesn't play short sounds after complete silence).
Removed driver from Windows 11, now KA3 became MUCH MUCH louder. (with driver 60% was getting loud, now it's pretty loud at 10% windows volume).
Dear friend,hello. i had the same exact issue (sound fading) with installed KA3 drivers on windows 10. then i installed the firmware 2.0 thinking it would help to resolve the problem. but instead it got worse: now i hear pops (when switching the tracks or youtube videos) AND sound fading is still the same. what should i do?
also people here are talking about control panel on windows but i don't see one at all...
upd: ok, found and installed the control panel but it says "no devices connected"... i have drivers and fw already installed.
upd2: also found a super annoying bug: sometimes (not often) something is blocking sound completely! i can't even run youtube videos (they just buffering at 00:00). unplugging KA3 resolves the problem.
Dear friend,Hi there! Does anyone know if this works with a PS5 or if it supports UAC 1.0?
I don't understand. Whats the difference between fiio control app and fiio control panel? I'm on windows 10. I'm using KA3 as a usb dac...Dear friend,
You could try to turn on the 'hardware mute switch' for the KA3 in the FiiO Control app to see whether it helps?
The FiiO Control panel is for FiiO USB DAC driver. So the KA3 using FiiO USB Audio driver is not compatible with it.
Best regards
The FiiO control app is only available for iOS and Android and allows for configuring the KA3 parameters something that cannot be done with the control panel.I don't understand. Whats the difference between fiio control app and fiio control panel? I'm on windows 10. I'm using KA3 as a usb dac...
Should I delete fiio control panel and instead install fiio control app on windows?
I don't if you can use it with an emulator.I've installed noxplayer (bluestacks alternative) on pc. I've downloaded the app. Now i see this screen: https://i.imgur.com/nl1L0yg.jpg I can't get through it!
Is it really the way? To install the android emulator on pc? really? It's awfull
Thanks, I'm dumb). I'll try itI don't if you can use it with an emulator.
Don't you have an Android smartphone?
You can connect the KA3 to the phone, make all the configuration you want and then the changes are permanently stored in the KA3 memory.
Dear friend,I don't understand. Whats the difference between fiio control app and fiio control panel? I'm on windows 10. I'm using KA3 as a usb dac...
Well, i turned hardware mute switch OFF and now its a bit better (no pops) and overall a bit more "stable". But fade in didnt go away AND sometimes the sound become muted. for example, I watch a stream on twitch, everything seems to be fine. but suddenly - silence. the video continues without sound. I reload the page -- everything is fine again. it happens rarely, but it really pisses me offDear friend,
Best regards
Dear friend,Well, i turned hardware mute switch OFF and now its a bit better (no pops) and overall a bit more "stable". But fade in didnt go away AND sometimes the sound become muted. for example, I watch a stream on twitch, everything seems to be fine. but suddenly - silence. the video continues without sound. I reload the page -- everything is fine again. it happens rarely, but it really pisses me off
