Originally Posted by donunus /img/forum/go_quote.gif
and for heavens sake, stop using the ipods eq! it adds too much clipping. just leave it off. With your current amp, I wouldn't suggest hard to drive cans like the k701. The denon d2000s might do ok as well as the grado sr325i. You might also want to try the sennheiser hd600s as well
Originally Posted by strangemusic /img/forum/go_quote.gif
Furthermore, don't use the iPod preset EQ! I agree with posters who have already said "find a pair of phones that accentuate what you want to hear".
You are absolutely correct, I appreciate that. I can't believe after all this time, I finally realize I am better off without using that dumb EQ. It's funny, I've had those shure se530's for over a year NOW i'm finally starting to appreciate them more as a result of disabling the EQ presets. Find a pair of phones that accentuate what I want to hear only makes more sense.
Originally Posted by Charles_1985 /img/forum/go_quote.gif
Your whole post says Grado except for the soundstage part. Grados are genre-specific. I have MS-1s (like Grados except a bit more neutral) and while I love the way they engage me in fast music, I always end up putting on my AD700s since the soundstage is so awesome. It's even better on the D2000s.
If you can live with the limited soundstage, the Grados are the way to go. Rock/acoustic are where they really shine. The D2000 is a better headphone for listening to a variety of genres.
Also, not sure if you saw the sticky but there's a dictionary of all the terms like "bright":
http://www.head-fi.org/forums/f4/des...ossary-220770/
If you use MP3Gain and normalize your music to 89.0 db, you shouldn't have any clipping while using the iPod's rock EQ setting.
Originally Posted by Ninja13ear /img/forum/go_quote.gif
i was in the exact position as you. i couldn't decide between those 3 headphones. i was able to auditon the k701 and the grados ranging from sr60-rs1's--except for the 325's(sold out). i never tried the denons so i cant comment on them. i love my 701's, they sound great, but not as great as the grados when it comes to rock. if i was you, i would completely and fully go for the grado's! its very frustrating choosing, but you cant go wrong with either. just buy one and you wont regret it!
Originally Posted by yashicaman /img/forum/go_quote.gif
Decisons, decisions. In the best of all worlds, you'd just buy the 3 headphones that you list and call it a day. I have a pair of AKG 701's and a pair of Grado 325i's. I adore them both, but I love the Grado 325i more for its ability to rock. I like the AKG 701's for jazz and classical, but the Grado 325i's for metal, punk, and rock 'n' roll. I guess that if I had to pick, I'd run with the Grado's. I'd get the 325i's now and in a year or two maybe score a pair of AkG 701's.
Honestly, as subjective as this sounds, I think I'm inclined toward the Grado's. From what I'm hearing, Grado seems to have a passionate following, almost cult-like. I'm passionate the same way when it comes to Apple computers/products. Discovery is something I'm excited about and looking forward too. And thank you so much for referring to me to glossary terms of sound. That certainly educated more on my understanding.
Originally Posted by Chu /img/forum/go_quote.gif
I'm sort of curious, what exactly is the sticking point in your decision?
Those three headphones are nothing alike and I'm wondering what specifically is causing you so much trouble in deciding after reading so many reviews.
One note on Grado's that I haven't seen in this thread so far -- some people find them supremely comfortable, some people literally have their ears bleed after using them. If this ends up being your final choice then you need to get them someplace where they are returnable if you're in the latter category.
It's also a little odd you have open and closed phones on this list. Nothing in the op says anything about the listening environment. Is one naturally more suited than the other?
I think maybe I'd prefer open headphones, because closed headphones often times produce that seal that I don't like. I don't like that congested sealed, echoey feeling I get. Even the shures give me that closed sealed feeling that I'm not too particularly fond of. I feel like it takes a bit a way from the natural sound of things. But honestly, If not opposed to closed headphones either. If it can produce a better sound, then by all means, I will go for it.
On the other hand, closed maybe good, because my wife can get a bit bitc*@y, when the leaking out sound bothers her. And for good reason
I love my wife.
I will primarily using these headphones in my home. When I travel, I will most likely use my shures.
Originally Posted by DoomzDayz /img/forum/go_quote.gif
you should do this anyway because many recordings will have clipping by default.
it only takes 1 or 2 nights left on running.. you can even listen to music while it does it. once it analyzes the songs once, you can change them a lot quicker. any songs already analyzed will take a second.
drag whole music folder into mp3gain, listen to music for a while, hit album gain, and do whatever.. sleep, listen to music, etc.
if you're listening to music while it is playing, all it does is skip that one file, so just run it again and it will take a couple seconds to do whatever song you were listening to.
I would like to avoid actually modifying the actual music itself, because I'd be afraid I may not like the result and I wouldn't be able to get it back to the original way it was. I don't mind screw with metadata a bit, but that's as far as I go. 95% of my music is in Apple Lossless. I deleted almost all of my mp3's. And was able to obtain almost everything in lossless. It was the best decision I have ever made. Although, I made a huge sacrifice when it comes to capacity.
I appreciate everyone's quick responses/feedback. So far, the 325i/k701 is on my list.
