Nak Man
- Aug 6, 2004
Lini confirmed the rubber idler (I still keep my first table 1215 with similar drive method =), so no need to figure out further what's on the underneath. However, those plastic gears and small rods which are attached to arm's base are one of the reason Dual automatic arm could not give optimum sound.
Sorry to state the obvious but headshell is where the stylus / cartridge is mounted. If you put your finger on the pickup 'tab' then you can slide or push them backwards (gently if you're not sure with the direction), better be safe and remove the stylus before doing any of this.
Once the lever is all way back, the inner headshell that looks like this will fall down with the cartridge (do you remember to remove the stylus ?) and you can see 4 prongs that go toward the armtube. These are headshell pin connectors that can get problematic and cause intermittent sound loss and or hum. Give them a careful cleaning + little contact spray and install them back the way you removed them. Make sure all contacts are good and headshell feel springy before securing the lever back to front. I was hoping there's a user manual at this site or clean pictures of regular maintenance but I couldn't find any. Hope my english did not confuse you more. =)
You can get N91ED replacement stylus for $25 over here or check out the other selections - but let's get rid of that hum first. I wouldn't recommend getting used stylus for various reasons, one of them being rough handling. =)
Originally Posted by pne Can you describe the headshell connector? Not sure which part this is. The hiss and hum is very annoying and present in all the records I've tried. (cleaned the stylus and records) So I think it may be a grounding issue or I may need a new cartridge after all. Would ebay be a good place to shop for cartridges? |
