alex_cs
- Jul 1, 2006
Hi there,
I recently got a Juli@ and have only just began to set it up. Im having a problem with ASIO playback in Winamp, in that winamp will refuse to play any mp3/flac/wav when ASIO output (the juli@'s ASIO) is enabled. when directsound is enabled, all files play.
tracktion is saying that the juli@ asio driver is functioning properly, so im a t a bit of a loss, there appears to be basically no support on the internet about the juli@.
files play in foobar fine, but i havent used foobar much, and cannot tell whether foobar is using ASIO playback.
Additionally, the optical out is working, but the coax out is not producing any signal to the zhaolu.
is there some big stuff im missing here, it almost seems like there is a whole lot of options missing in the julia software. im running 1.18 drivers if that could be the problem?
thanks.
thanks.
