NickleCo
Previously known as DatDudeNic
- Apr 14, 2016
I bought it from a local seller@DatDudeNic
Where did you get the 2pin to 4pin JH Audio IEM adapter? Would you send me the link? I’d like to try some of my 4.4 bal with Angie II. Thanks.
Very nice! Angie is peobably one of the most tip dependent iems i have ever owned. Having excess rubber in the nozzle gives it a more holographic stage and more treble.I have spinfit cp100, aet07 & aet08
I like aet07 imo aet07 more open more forward for vocal
Wm1a
Wm1a leans towards the natural side of things (warm) but with the current firmwares its more toward bright neutral. Its very good especially if you prioritize battery over drivability, i need to turn high gain on both se and bal to get to a vol im comfortable with (ymmv, a lot of users stay in low gain and are completely satisfied with it). Its for the purists rather than the streamers since it only has bluetooth as a form of wireless connectivity. I also isnt the lightest or slimmest dap out there but it is one of the better designed (if you like symmetry like me). UI is very straightforward, intuitive and mature. Also the sq of the dap can change when firmware changes which is either a pro or a con.Wm1a
How impresion wm1a sir..??
I want to upgrade dap to ak240
How impresion wm1a vs ak240..?
Thx u sir.. God bless
Upgrading the cables make a world of difference! Been using diy csbles for quite some time now since i know a lot of diyers and to be frank it is much easier to get my cables fixed if something goes wrong.I try to use accoustune aet06
Wow is very confort and this sound very nice..
AK Angie IEMs
It is super tip dependentAngie II is mesmerizing but you need to choose the right tips though.
Thank you. Angie on AK site is selling for 699 now. Is it good to pick or extend the budget and take the angie II version?
