Originally Posted by kyleisgreat
odd question for a music forum, but....
I have a macbook non-pro. I got it because I liked the 13.3" screen, I needed it to be portable. I take it to campus everyday so it's nice and small. Since size isn't a big thing for you, I don't know if it is your best choice. You could easily get a 15.4" windows based laptop for almost half the cost of a macbook pro, with all the fixings.So if money is any concern, I would go with windows. Now let me talk about the mac os for a second. I had heard a lot fo things about mac os being much easier to use and a lot nicer than windows xp. Now that I've used it for a while, I've found it is a little easier to use, but I don't really notice a difference with everyday tasks. It has a lot of nice features though. Tiger OSX (incl.iLife) takes up about 17GB of space on your hard drive, and it's not wasted. You're going to get a ton of programs that allow you do anything with pictures, music and video. And I don't just mean managing, you can create. You've got iMovie, you've got garange band, you can make your own stuff. In adition to all this, you'll get bootcamp, which means you can run windows XP on your computer aswell. This is nice if you have some programs that just dont have a mac equivalent( or you prefer the windows counterpart, Visual Design for me, xcode just doesn't cut it) If this sounds nice to you, get the mac. Even if your not going to take it around town it's nice to be able to use your computer on your couch, or on your bed, or anywhere in your house.
I already have a athlon64 3000+, 1.5GB ram, 850GB hdd, gf4 ti-4200 PC, but I don't wanna use Windows, I'm there for the OS. I could run a hack, but well.. it would be a hack, and I wouldn't support Apple, and .. ;/
I'm not intrested in wasting money on a PC machine which I might end up running Windows on because that's not what I want.
I ask about sound quality since your software choices are quite limited in mac os x.
Also the macbook pro are just 4.3% more expensive than a similair speced Dell inspiron 6400/E1505 here in Sweden (both are very expensive.)
(04:36:53) (aliquis) the inspiron in that case got 1680x1050 gfx and 8x dvd
(04:37:13) (aliquis) but the macbook pro got x1600, 802.11n, fw800, webcam, 1.08cm less thick, 0.26kg less weight..
Apples laptop got better hw, os and are just 4.3% more.
I'm mostly doubting because I'm unemployed so I'm short on cash and since the stupid osx86 project exist I CAN run os x without paying... But =P, I've always wanted a mac and I know I won't have any troubles, and it's sexy ;/
