hciman77
- Feb 25, 2004
Originally Posted by IPodPJ /img/forum/go_quote.gif I can't say conlusively what the reason is for the sonic differences that I can hear, but I know it isn't placebo. I'm not an engineer so I can only deduce what might be causing it. |
Originally Posted by hciman77 /img/forum/go_quote.gif Probably not since the audio stream will be buffered before output. There is only one place that jitter matters and that is at the DAC, the DAC has a word buffer and does not process a word until it is full, thus variations in bit-timings are averaged out. So far nobody, and I do mean nobody, has found jitter at the levels found in commercial audio products to be ***reliably*** detectable. The poster child for bad jitter is the Oppo HD970 which clocks a massive 4ns of random jitter. However no rigorous test of jitter has found it to be audible below 20ns in music for deterministic jitter (Jitter correlated with the signal giving definite sidebands) or several 100s of ns for random jitter (jitter spread over the spectrum). Jitter just isnt worth worrying about. |
Originally Posted by IPodPJ /img/forum/go_quote.gif You showed that the waveforms were identical, so obviously we can rule that factor out. |
Quantum physicists don't even fully understand the nature of electrons (as they have observed single electrons in multiple places at once), so surely you aren't going to tell me that what flows from one end of your system to the other is going to be identical every single time just because a file is called "bit-perfect". |
I can't say conlusively what the reason is for the sonic differences that I can hear, but I know it isn't placebo. |
Originally Posted by xenithon /img/forum/go_quote.gif Is there an ALAC encoder for EAC? |
Originally Posted by xenithon /img/forum/go_quote.gif What is the verdict then about iTunes volume control? |
Originally Posted by Elephas /img/forum/go_quote.gif I've never had any problems ripping ALAC with iTunes, Error Correction On, with a Plextor or Pioneer drives on WinXP or Vista, and also a MacBook/Mac OS X. I've done various comparisons with iTunes, EAC, dBpoweramp and foobar and am satisfied that iTunes ALAC rips sound equivalent to FLAC and WAV rips. There's no way I'm using WAV, no tagging. This thread was a waste of time, obviously there was a hardware issue or "user error," or both. |
Originally Posted by n4k33n /img/forum/go_quote.gif Is this what happens when 50 year old audiophiles finally buy computers? |
Originally Posted by IPodPJ /img/forum/go_quote.gif FYI, do you know Microsoft purposely inflates their software size to take up more hard drive space? They do this so that inexperienced people will keep having to upgrade their hardware, which usually means a new computer, which also means another sale for Microsoft. Several open source teams analyzed the code for Microsoft Office and found that it was 40 times larger than it needed to be. |
Originally Posted by xenithon /img/forum/go_quote.gif Right, so lets say you are pedantic such that you want to neither use iTunes (Mac) or Max to rip - you want to rip with EAC, but still want ALAC files to use on your Mac. Is there an ALAC encoder for EAC? |
Paranoid much ? Maybe try taking off the tin foil hat ? This seems to be a case of PEBKAC with a very,very heavy dose of placebo effect. |
Originally Posted by IPodPJ /img/forum/go_quote.gif If timing errors and jitter don't contribute to audio differences, why do people choose I2S over SPDIF if they are both bit-perfect? Why do people buy products from companies like Empirical Audio that re-clock? Why do people buy digital or analog RCA cables that yield different sonic flavors? |
Originally Posted by bigshot /img/forum/go_quote.gif This thread does not give accurate audio data. See ya Steve |
Originally Posted by bigshot /img/forum/go_quote.gif This thread does not give accurate audio data. |
