D2X2903
- Dec 12, 2003
I've been meaning to post this for a while. I've been cutting grass using noise-isolating (earmuffs?) overtop a set of MX300 earbuds plugged into my Karma. Well, the earmuff headband broke (again) and my MX300s hurt my ears - theyre too big for me (not to mention they sound tinny and weak).
I was able to try a set of E2c's and some sort of special cushion (felt like a plunger when they went in... they were grey and kind of umbrella shaped going from the nozzle back to the base of the unit...) and they sounded decent for the track and a half I was able to try them with.
I checked out headphonereviews.org for earbuds and canal phones, and the highest marked phones were also the one I had seen mentioned and praised quite often here during the past week or so;
E2c seem to be the most debated for greatness or pure uncomfort or wonky sound
I believe the 888 buds referred to in many posts are the Sony E888s, which I have seen praised many times
Finally, there are the EX-71/81, which seem to be lesser compared to the E2c buds
I'm leaning towards the E2c buds because I've heard them before and because Shure is the name brand I recognize the most for canal phones. However, I see that the E888s have a reported range of 8-27,000 Hz while the E2Cs have a more "typical" 20-20,000, which makes me consider the E888s more seriously...
Do either of these isolate better than the other with the standard pads? Would you recommend one of these over the other for a loud ambient environment? (If they don't isolate enough, I can just use a pair of isolating earmuffs again) How would these compare to KSC-50s for use in a car or some other quieter environment?
Thanks for your time.
