GuruTech
- Feb 22, 2010
I have heard that Mac is considered better while doing audio recording and editing
You can't get much lower latency than Linux. Install the real-time kernel and make a few adjustments to ALSA. With Linux you have such control that you can even control the number of packets of music data being send to each processor and their timing.
Check my web site under Linux Audio.
Thanks Dynobot, i use Linux mint, then installing the real-time kernel and configure Alsa is enough? is necessary install Jack?
Huge is relative so no need to go there. IMO everything makes a difference how big it is or how much it matters is up to the listener. You sound like you are in the Bits-R-Bits camp, which is fine, it means that you never need to upgrade Dac's or change software based on sound, because they all sound the same as long as its bit perfect. In the long run you save a lot of money and effort.
Just curious, did you use any of my instructions? If so did you get huge up anywhere?
For the first question, yes, i have some problems with Mpd configuration. i dont understand the second question, my english is poor" class="bbcode_smiley" height="" src="http://files.head-fi.org/images/smilies//frown.gif" title="
" width="" />![]()
