markjia
- Nov 2, 2001
I realize that CD-Rom are not fragmented. What I'm saying is that given a hard drive's higher seek rate, fragmentation is not a problem. I'm using digital video as proof that fragmentation will not have an impact. I'm not saying that a drive that is horribly chopped up will still produce great sound, but so long as it is maintained every now and then and not used excessively, will playback audio just fine. 24bit 44.1kHz sound is only 150KB/s, insignificant for a hard drive (mine can do 200-300 times this amount).
Jitter is not at all related to a hard drives access time. They are entirely different matters. You pointed out yourself the huge difference in magnitude. They are seperate matters, and produce entirely different results. The effect of fragmentation is choppy playback, not at all the same as jitter.
An ethernet based playback system is really little different from a computer. They still use hard drives, and if you delete files, will result in fragmentation as well. It is kinda just like another bus. Instead of transfer data over SCSI or IDE, it uses 10/100. Ethernet is actually even slower than using a hard drive, and if your network is not well designed and/or overly congested, you can end up with a lot of collision and lag. SCSI or IDE over PCI will be faster and more reliable. Ethernet based drives are mostly for convience and muiltiple users.
