zantetsuken
- Apr 25, 2008
so through my device manager it seems i have a SB Live! onboard sound. which can run 5.1 surround sound. if i wanted to plug my phones in, how can you tell how much juice this soundcard can deliver?, and how can you tell if ur phones will work at a decent level.
some more info
Audio - AC97 2.3 Compliant interface
* Supports 2, 4, 6, or 8-channel audio
* Dual AC-Link: supports up to two codecs
* Dual S/PDIF: supports two simultaneous digital outputs; handles stereo PCM or AC-3 output
* 16-bit or 20-bit stereo, 48kHz output and 16-bit input streams across AC-Link
* 24-bit, 96kHz stereo output on the secondary S/PDIF output
Creative Sound Blaster Live 24-bit onboard audio
* 24-bit / 96KHz audio quality
* 100db SNR clarity
* Up to 7.1 CH Surround Sound, Dolby Digital ready
also is damage possible to your phones if the power is not enough?
some more info
* 100db SNR clarity
