Is there a way to make my Beats Studio Headphones less tight?
Dec 23, 2011 at 11:32 AM Thread Starter Post #1 of 5
Icyhectora
So, i just got them, and after trying it out for a day, they're really tight, and my ears ache after some time, and i have to keep taking them off. And especially since i wear glasses, it really digs a mark in my head, and also on the earcups' padding thingy. What i'm asking, is there a way to make them less tight? Like a way to adjust them? Thanks.
Dec 23, 2011 at 11:48 AM Post #2 of 5
Find an object (stack of books, speaker, etc.) that's a similar size to your head and let them stretch out for a bit.  Or just return them and find more comfortable headphones with a lower price and better sound quality.
Dec 23, 2011 at 12:13 PM Post #3 of 5
Well, thanks. I'm just afraid it'll damage them. And yeah, i know, Beats aren't exactly good at all. I already knew that when i bought 'em, still, i like them. Are there any other ways, though?
Jul 5, 2013 at 11:01 AM Post #5 of 5
heat up a bowl of water and get it at around 75-85 degress cels (pretty hot, but not all the way upto boiling)
make sure you're wearing gloves and dip a small soft towel in them, keep them soaked for a bit.
drape the electronic parts pf the headphones (and holes and the cans) with plastic or electric tape
stretch the headphones over a few books and wrap the hot towel around the headband, right around the middle and nowhere else.
the heat should make the plastic more flexible without damaging it - just make sure it isn't hotter than 85 degrees.
keep them this way for a few hours and they should be fine.
