Unless you can find a used receiver, a t-amp is your best bet.
However, if you are looking at the Lepai A2020+, then you might consider the Indeed TA2020 + this power supply. Or get the Indeed TA2021 which comes with the power supply. Better quality t-amps than the Lepai.
