Speakerjunky
- Oct 23, 2008
I produce electronic music (electro house, trance, etc...)
I use the Tc Electronic Konnekt 8 for my DAW
Is it enough for my Beyerdynamics DT 990 Pro (600ohm)?
Here are the specs for the Konnekt 8
Headphones Output (Ch. 1/2)
Connectors 2 x 1/4” Phone Jack (Stereo)
Impedance 80 Ohm
Gain Level Range -80 dBu <> +16 dBu @ 300 ohms
(analog gain scale)
THD+N < -94 dB (0.002%) @ 1 kHz, -1 dBFS
SNR >103 dB(A), > 100 dB, 20 Hz to 20 kHz
Freq. Response +0/-0.1 dB, 20 Hz to 20 kHz
Crosstalk < -100 dB, 20 Hz to 20 kHz
Power @ 40 Ohm Load 200mW
Power @ 600 Ohm Load 93mW
TC Electronic | Audio Interfaces | Konnekt 8
I have to crank the volume all the way up just to hear at a pleasing level. At that level I think distortion is being introduced and the sound doesn't sound clean and tight. I sure would like to avoid purchasing a headphone amp but if I have to, I was thinking about the Octavart 01. I should be able to s/pdif the Konnekt 8 with the Octavart 01 correct?
Any input would be greatly appreciated thanks!
Impedance 80 Ohm
(analog gain scale)
