J@CKY
- Apr 28, 2007
I have always confused which one is the determining factor in a "computer as source" audio setup.
My desktop computer has an on-board sound card that provide S/PDIF out (both coax and optical). I am not sure if an external USB to S/PDIF out digital converter will deliver a better result than my on-board one. (say M2Tech hiFACE, or V-LINK)
I bet the answer will be yes, external ones will be better than on-board one. But I want to understand why.
To me, both cases are the same as the process should be simply converting 1010 digital signals to another interface only. Theoretically, there should have no data lost. But apparently, there must be something I have missed as many of the head-fiers stated that there IS in fact some difference in terms of SQ when comparing both cases.
Basically, my question in a nutshell will be:
Are there any difference in sound quality if rigs are connect the following ways?
1. Desktop computer ► USB to S/PDIF converter (no brand, cheap one, or on-board sound card with S/PDIF out) ► DAC ► Head-Amp ► Headphone
2. Desktop computer ► costly USB to S/PDIF converter (say M2tech hiFACE) ► DAC ► Head-amp ► Headphone.
Assumptions:
1. same track of music being played in both cases (say 24b/48k)
2. the cheap USB to S/PDIF converter support the sampling rate and depth of the music being played without upsampling. (i.e. native 24b/48k in this example)
3. DAC, Head-amp and headphone are the same in both cases.
_____________________
P.S. I have opened a thread in Sound Science board as well, but want to receive more input as this board has more potential reader
http://www.head-fi.org/t/568043/
Assumptions:
