Fairchild
- Dec 22, 2010
Hi all,
So I have a fairly new monster turbines (normal model, not the pros) and I have been testing it out... it took some time to find the right tips, the stock ones were directly too big for me... finally I settled on the XS supertips (gel or foam, both work well) and while I am liking the sound I have noticed that driving them to a reasonable level in my laptop is very easy, takes like 15% of the volume, but when I put the same songs into a nano (3rd gen, the square one...) I need to significantly increase the volume to more than 50% to get the same level. I must say that I dont listen to loud levels, actually less loud than most of my friends...
This surprised me since I was expecting that with IEMs I would reduce the volume. Before I was using Sennheiser mx500 earbuds and I would use them at 40% or so...
Now the questions:
- Does this happens to anyone else with these particular IEMs?... it didn´t look from the specs that impedance and sensitivity were too different from the senns
- Is it bad for the hearing to raise the volume if it is in order to reach the normal volume? might be a stupid question haha, I am not sure if sound pressure refers only to the volume
- Do I need a new DAP? I don´t like the idea of portable amps, kind of kills the whole portability idea... suggestions?
Any input will be welcomed
Now the questions:
