Geruvah
- Jan 3, 2009
Pretty sure people here knew this but I never got the answer so just in case:
"It is completely true that the Super.fi 5 pros use the same drivers and
components inside that we install in the custom UE-5Pros.
The same goes for the Triple.fi 10 pro that is designed after the custom
UE-10Pro. Same components.
The difference between the two mentioned ( 5 / 7 pros)is that the 5 is a
dual driver with a single crossover and the 7 is a triple driver with a
two way cross over.
Sonic wise the 5 is pretty balanced and even where as the 7 has a boost
in the low end. You will receive more detail and better separation in
the 7's.
Hope this helps !"
UE customer service. So I'm going to be looking at either the 7's or the Westone ES3x.
two way cross over.
the 7's.
Hope this helps !"
