papomaster
- Aug 13, 2006
I did a preliminary version of the stand using some pine, and here are some pictures of the construction :
I glued the two "arms" on the bottom, then screwed them both to the vertical piece while holding everything in place.
Then, I put a wooden screw through the upper corner to hold the horizontal bar in place, and glued the two pieces together with the screw in.
Then, using another wooden screw, I drilled a hole in both the pyramids and the two arms, and glued them with the screw.
You can see the screw here :
Now with a holder to put some pressure:
Another view of a pyramid :
Hopefully this will be finished and varnished by the end of the week.
