deadlylover
The amp is fully balanced like most stat amps, you will get a balanced output even with a single ended input, it doesn't matter.
If you use RCA you will probably ground the cold portion, which means there will be no signal from the cold. This leaves only the hot to provide the signal, therefore only have half the board pumping up the signal.
