nanahachi
Head-Fi FAQ(s) Volunteer
- Aug 16, 2002
Here's a quick question that I hope will be easy to answer.
Until recently, I've been using EphPod with my 2nd Gen 10gig iPod with no problems.
Then, I picked up a 4th gen 40Gig iPod and tried to sync it. No Dice. So I installed iTunes, had to reformat the 40, finally got that working.
But somewhere, somehow, the little iPod icon in my sytem tray (which used to allow me to "unmount" my ipod by right-clicking on it) is gone. I don't know which program first put the icon in the tray, but I want it back! I dislike using the Windows XP "safely remove hardware" grey and green icon thing.
any ideas?
Also, if you have any thoughts how to best manage using 2 iPods on the same machine, that would be great. I am going to search here for some answers, but thought I would just pose the question here too. My thoughts were to use EphPod with my 2nd Gen and iTunes with my 4th.
thanks guys!
any ideas?
thanks guys!
