Ipod, Rockbox, Replaygain pre-amp and Battery Life
Jul 11, 2007 at 8:07 PM Thread Starter Post #1 of 4
onocentaur
I use my Rockbox on my iPod (+ amp via LOD) with ogg files, all replaygained. In Rockbox there's a pre-amp option with Replaygain; does having the pre-amp at -12db increase the iPods battery life? Obviously it will reduce the battery life of the amp as it has to do more amplifying, but my amp lasts a lot longer than my Rockboxed iPod! I thought maybe that as the iPod is putting out a reduced signal it would require less juice, but I also thought that perhaps the extra processing required to reduce the signal level would negate any power gains.
Jul 12, 2007 at 6:52 AM Post #3 of 4
No, you misunderstand, the codec is irrelevant here - I was just giving some background info. Pre-amp battery effects is the point. Thanks anyway.
EDIT: the word from thr rockbox forums issss: no effect on battery life.
Jul 27, 2007 at 4:14 PM Post #4 of 4
I got a <a href="http://www.ipodjuice.com">new ipod mini battery</a> from ipodjuice.com a while back and it holds a charge so long I don't have any trouble with it wearing down too fast.
