Xprime4
- Dec 31, 2012
Hi there,
I've got an m-stage matrix and a Ipod 80gb. My main headphone in my bed are the hd650. I only use this setup an hour before sleep pretty much everyday to fall asleep. it works Wonder
At the moment, i'm using a cheap cable the goes out of the ipod jack to the rca of the amp.I like the fact that i can control the volume from the ipod (desktop amp is on a bed table and volume is far away when you're pretty much asleep).
I know you can't control the volume from the ipod dock , but is the quality SIGNIFICALY better going that way? IT doesn't bypass the ipod DAC but i guess there is less parts in the signal's way.....
I'm not really a cable guy, but what ipod dock to rca cable should fit the bill for me?
http://www.ebay.ca/itm/251149537628?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I was looking at that one but i'm unsure of the quality and 50$ is really the max i would spend for a cable...
Anything cheaper would work? i can't call from amazon.com for electronic but i don't know about cable
thanks
thanks
