Originally Posted by Febs
Should I keep five different versions of my music on my portable, all EQed differently?
By the way, do you have any familiarity at all with Rockbox's eq?
I havn't seen the Rockboxes EQ no, as my Ipod is 3G won't support it, but I doubt that it will stand up to the eq in apps like Protools or even Cool Edit.
I could of course be completely wrong and should really try it before casting aspersions though, so if it's the best one you've tried then I guess it fits your needs.
But I would generally stand by the ideal that if you want the best from your music you are better off addressing the playback equipment, rather than trying to fiddle with what has been done in the studio with a freeware pluggin.
Especially since what you are re-eq'ing has probably had massive amounts of compression applied in the studio if it's modern pop music, then had most of the life squashed out of it by a compression codec like MP3. Frankly to claim that this can approach Hi-Fidelity by applying further eq of the standard found in most consumer level equipment is a nonsense.
Originally Posted by Chri5peed
Most likely, but that doesn't stop LAME being the best mp3-encoder(by general consensus, not my opinion) and therefore wouldn't it be considered sensible to use Lame, especially as its free.
Personally I would use Cool Edit Pro (now Adobe Audition) with the complete Fraunhoffer MP3 Pro exporter pluggin as this gives the most flexibility and best results in my experience. Autodesk Cleaner is also very good for batch processing really large amounts but both of these packages cost hundreds of pounds and I don't have to pay for them personally so....
99% of people probably haven't heard of AKG, Beyerdynamics or Etymotic, doesn't stop them being great headphones. People will use what they're given, they percieve as the best or is easiest until they're shown better..
Without recourse to argument from popularity, which you are quite right doesn't necessarily equal quality, but you did use first, all the brands you have mentioned, except Etymotic, would be fairly well known to anyone who has ever had any reason to buy headphones or microphones in the last 50 years anyway. LAME is just a tad more obscure than this.
Originally Posted by seanohue
..how can I set iTunes to take all my lossless files that I have on it to 320 AAC which I like to play on my iPod?..
Go into the preferences>advanced>importing tab and select 'mp3' and 'custom'. This will open the custom settings and allow you to set Bit Rate and VBR quality etc.
Next Right click (PC) or Control Click (Mac) on the categories at the top of the library and check 'kind'. Then arrange the view to 'kind' by clicking the top of the 'kind' column. This will show all your Apple Lossless files together. Select them all then and re-encode by Right click (PC) or Control Click (Mac).
