ipod battery life with lossless
May 4, 2007 at 6:24 PM Thread Starter Post #1 of 42
robm321
I have a 30gb ipod video. How long would my battery last with lossless compared to AAC? Just approximate....
May 4, 2007 at 7:50 PM Post #2 of 42
I can't say exactly for the ipod video, but on my nano 2g it was certainly a big drop. Somewhere between 40-50% of normal. For the video ipod it'll probably be similar.
May 4, 2007 at 9:35 PM Post #4 of 42
so it doubled going from lossless to a compressed format (in this case AAC?)
May 4, 2007 at 11:55 PM Post #5 of 42
To be honest I'd assume the drop to be much worse on a video model because of the constant harddrive spinning.
May 5, 2007 at 12:29 AM Post #6 of 42
I have a 5.5 gen Video Ipod. With Lossless I get around 2.5hrs if you dont ever touch it. With regular use less than 2 hours.
Does make a good argument for high AAC use.
Oh no I said it! Im gonna regret this! I just know it?
May 5, 2007 at 3:19 AM Post #9 of 42
is there an easier way to convert to FLAC than having it do it album by album? it doesn't even keep all the tags or song info for me anyways. do you think that rockbox would actaully increase the battery life for an ipod that uses lossless?
May 5, 2007 at 3:38 AM Post #10 of 42
no, i don't think it would. you could look into dbpoweramp for conversion. i believe rockbox does support alac, though.
May 5, 2007 at 3:41 AM Post #11 of 42
Originally Posted by zip22 /img/forum/go_quote.gif
have you actually tested that, trose? using rockbox doing an actual rundown test, people get 7 hours with flac.
http://www.rockbox.org/twiki/bin/view/Main/IpodRuntime
the actual firmware should be much better, certainly more than 2 hours. its rated to play video for 3.5 hours and you're claiming it only gets 2.5 with audio?
without rockbox. I use apple lossless with Itunes battery life is terrible!
May 5, 2007 at 4:06 AM Post #13 of 42
so have you done a complete rundown test?
May 5, 2007 at 4:43 AM Post #15 of 42
Very good point.
Video is much much more intensive. Most likely you have just bad charges.
Is there a reason you need lossless? With 320kbps MP3's I get about 10-12 hours. So unless you are 100% certain you can hear the difference, is it worth the battery life?
