ckhirnigs113
- May 19, 2005
Hi,
I have a 4G iPod Photo 40gb and I am having quite an ordeal with my battery. About a month ago I started noticing that my battery wasn't lasting near as long as it used to. Not just that, but my battery would drain to nothing while the iPod was turned off.
I have since then replaced the battery "twice" myself, but this has not helped at all. I know it's not a setting on my iPod like the alarm etc... In an effort to fix the problem I have reset, restored (with multiple firmwares) and tried everything in between, but nothing has made any difference.
I am starting to think it must be a hardware issue, like something is always active even when the iPod is turned off. Has anyone experienced anything like this. I am out of warranty, but I really hope I'm not out of luck. Any advice would be greatly appreciated! Thanks, Chris
