sputnik13
- Feb 8, 2008
Umm, is it also possible the unit is just bad? I've fixed a few 5th Gens, and there's some cases where you get horrible distortion in the sound because there's particular an SMT part that's prone to separation (not like coming off but losing enough contact to separate the signal) because of a horrible solder joint.
Believe it or not, try throwing the iPod in the freezer for a good 15 - 30 minutes, take it out and listen to it. Idea is that the cold will make the parts contract and let the contact settle in place for a little while. Another thing you could try is push down pretty firmly on the iPod to the lower left of the click wheel.
This problem with the SMT part is made worse if you leave the iPod out in the heat and can eventually end up with your iPod losing all sound. Doing an iMod or diyMod bypasses this problem because the SMT part is in the signal path between the DAC and the headphone/dock connector, while the iMod bypasses all of the circuits in the iPod after the DAC.
If you can't get decent sound with *ANY* music, I'd suspect it's the iPod itself.
