OOO! I get to make a "I hate" list! That's fun!
WOW.......I'm easy I don't like equipment that does not sound good and some crappy MP3 files.
He measured:
-0.01dB @ 20Hz and -0.08dB @ 20kHz into a 200 Ohm load, is that not as near as damn it ruler flat?
4.5 Ohm output impedance.
Less than 0.01% THD 20 Hz - 15 kHz.
106.8 dB playing zeros A weighted output noise
116 dB idle A weighted output noise
Go look at his results.
What do your measurements show?
4.5 ohms is higher than I would normally like to see, and would be potentially audible with some headphones (though those specs would be audibly transparent with the majority of headphones out there). For example, look at the Westone 2 IEMs. They have an impedance of around 20 ohms below 800Hz, but >50 ohms above 1kHz (and >100 ohms from 6-9 kHz). This means that if they are played from a source with 4.5 ohms of output impedance, low frequencies (<800Hz) will be attenuated by around 2dB, frequencies above 1kHz will only be attenuated by 0.75dB, and frequencies between 6-9kHz will have less than half a dB of attenuation. This effectively acts as a 1-1.75dB boost to the upper treble, which is potentially audible.
Alternatively, another IEM that might have an audible impact from this is the Shure SE535. It has a nominal impedance across most frequencies of about 25 ohms, which would result in an overall attenuation of about 1.5dB across most of the frequency range. However, the SE535s impedance drops down to around 10 ohms at 6kHz, which would cause a 3.23dB drop at this frequency. In addition, the impedance goes up to around 50 ohms at around 2kHz, which (as I mentioned above) results in an attenuation of 0.75dB or so. In other words, when used on a source impedance of 4.5 ohms, the SE535 will have frequencies in the 6kHz range attenuated by around 2.5dB relative to frequencies around 2kHz, which should be a noticeable attenuation in the upper treble.
Admittedly, these are fairly subtle changes, but they aren't inaudible - they should definitely be distinguishable in a proper double blind test. Interestingly, if I'm remembering from the last couple pages correctly, the person who was claiming a large change from the 4 to the 5 was using JH13 Pros, which could definitely have a very frequency-dependent impedance curve as well as a low minimum impedance (since that tends to be characteristic of BA IEMs, especially multi-driver BA IEMs). If that is the case (I can't find an impedance curve for the JH13s in a bit of quick googling), and the output impedance of the iPhone 4 and the 5 are significantly different, that could indeed cause an audible difference through those IEMs (even though most headphones would not exhibit any audible difference at all, from the specs I've seen).
You make good points about performance with low impedance headphones, but isn't the most telling phrase "these specs would be audibly transparent with the majority of headphones out there"? I think this is the main point that myself and BIGSHOT having been trying to make, to counter some of the nonsensical statements about the supposed lack of idevice audio performance. One poster characterized the sound quality of the iPhone 5 headlamp as "pathetic", which is patently not true.
I agree these effects are likely to be subtle, while accepting that the output impedance could be lower, to cater for a minority of headphones.
My two cents.....
And again, an impedance mismatch between the iPhone and a few models of IEMs says absolutely nothing about the sound quality of the iPhone itself. I can plug lousy earbuds into it and it won't sound good either. The quality of sound of a DAP is determined with line out, not with heaphones, because the headphones are always going to be the weak link.
Then my job here is done.
I disagree - the output of the iPhone is clearly meant to work with headphones, not just as a line out
Oh, and for what it's worth, I think you would have a very difficult time distinguishing a 1-2dB frequency-dependent boost or attenuation without a near-instant level matched switch
