I don't know the exact model of the chip but it's probably the same as the one in the iPhone 4. I had a chance to listen to an iPad 2 and also take some measurements. The headphone out will work well as a line out. It's undistorted, has low noise, and has a uniform frequency response. Here are some of my findings for the headphone out with no load:
- The output is 0.99V rms at maximum volume.
- Noise and distortion figures are low--THD+N and IMD are about the same as the iPhone 4 and the original iPad, and much lower than the Sandisk Sansa Clip, Clip+, and Fuze.
- Square waves and impulses on the iPad 2 have the same shape as on the original iPad and the iPhone 4. It uses a minimum-phase type filter. The ringing takes much longer to decay than on the Clip+ or the old iPod Video, but it doesn't exhibit pre-ringing.
The headphone amp is pretty good too. With a 16-ohm load, this is what I found:
- You have up to 570-580 mV rms for a 1 kHz tone before the THD+N goes above 1%.
- THD+N and IMD are much lower at typical listening levels with portable 'phones. The amount of distortion and stereo crosstalk is similar to measurements for the original iPad and the iPhone 4, and much lower than the figures for the Clip+.
- The headphone amp has low output impedance. I get around 0.9 ohms, the same as the iPhone 4 and lower than the ~1.4 ohms for the original iPad. The Clip+ is still a stiffer voltage source. I think some popular portable headphones might be designed for a player with higher source impedance (like the old iPods). Some of those cans might not sound as good on an iPad. I have my suspects. Fortunately, there is a quick fix for that.
I listened to an iPad 2 for some time and I couldn't hear any obvious noise or distortion on my headphones and IEMs. Hooking up the headphone out to a line in sounds clean too--at least on my Speakers. It's at least as good as some of the USB DACs that some folks attach to it. What's funny is that some of those even perform worse.
I wish I had a chance to install the EQu and Equalizer apps to see if the extra speed improves usability and stability.
