Introduction to FiiO L21 (3.5mm-RCA Coaxial Digital Adapter Cable)
Dec 16, 2015 at 4:42 AM Thread Starter Post #1 of 12
FiiO
Sponsor: FiiO
Guangzhou,China
Dear respected customers,
According to market demand, we specially made this new 3.5mm-RCA coaxial digital adapter cable to use with FiiO X3II/X5II/X7 and future FiiO models. Please kindly find the introduction as follows. The L21 will be shipped to our worldwide agents in the coming days, so you can kindly check with local agents
(>>Where to buy)
  for its availability. If you can’t buy it locally, then please go to FiiO Aliexpress store at this link:
>>Click here
Best regards,
FiiO Electronics Technology Co., Ltd.
Feb 23, 2016 at 1:54 AM Post #4 of 12
  The Aliexpress store says it's no longer available. Is it going to be restocked?
Hi chazb11 , it is available on our Aliexpress now , this is the link :
http://www.aliexpress.com/store/product/FiiO-L21-RCA-coaxial-digital-adapter-cable/1473108_32571318032.html
Feb 23, 2016 at 1:58 AM Post #5 of 12
  Prosím kabel je kompatibilní s fiio X3 1 gen.?
Děkuji VB
Hi Vlado , your question is " this cable can work with X3 1st gen ?" right ? if yes , the answer is No. L21 supports X3 2nd gen , X5 2nd gen and X7 now.
Jul 18, 2016 at 2:40 PM Post #6 of 12
I accidentally damaged the cable (coaxial-to-RCA mini) that came with my X5ii.  No problem, I contacted the retailer that sold me my X5ii to order a new one but he said it no longer appears on the price list and he is unable to order one.  Next I went to the FiiO website and I see that it's listed there but when I hit the purchase button it says:
"sorry this item is no longer available"
That's very concerning.  The primary use of my X5ii to transfer my digital library to an external DAC and on to an external headphone amplifier.  Obviously without this cable I'm in big trouble.
Next I went to the link that the FiiO representative posted above.  That just leads me back to the FiiO website that I was at previously declaring that the item is no longer available.
So what am I to do now?
Jul 18, 2016 at 7:58 PM Post #7 of 12
Will this work?
https://www.amazon.com/L21-Digital-Coaxial-Connector-Players/dp/B019OWCID6/ref=sr_1_14?ie=UTF8&qid=1468886181&sr=8-14&keywords=fiio+cable
Hope it helps...
Cheers!
-HK sends
Jul 18, 2016 at 8:19 PM Post #9 of 12
Nope. I live in Canada and Amazon.com won't send to Canada. Amazon.ca doesn't carry it.
Ouch, didn't realize they wouldn't ship to Canada.  I'll keep an eye out for one that can be.
Did you try eBay?
Maybe this: http://www.ebay.com/itm/FiiO-L21-3-5mm-RCA-Coaxial-Digital-Adapter-Patch-Cord-Cable-for-X7-X5II-X3II/351765965437?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37429%26meid%3D748cfbbbf1754ecba8b3289b65da3db2%26pid%3D100005%26rk%3D1%26rkt%3D4%26sd%3D381553329857
Hope it helps...
Cheers!
-HK sends
Jul 18, 2016 at 9:06 PM Post #10 of 12
No I haven't however I went directly to AliExpress and there they had it (even though an AliExpress link posted earlier in the thread said that item is no longer available). I ordered it. Lets seen if the order gets confirmed and when I should get it.
Jul 19, 2016 at 1:37 AM Post #11 of 12
I hope you are able to get one with no problem.  I got one myself because I intend to use my FiiO DAP as a transport for my home system...at least for a while.
The L21 cable should help me with that.
Cheers and All the Best!
-HK sends
Aug 6, 2016 at 8:27 AM Post #12 of 12
I ordered the L21 and a replacement adaptor from AliExpress, both arrived this week. They work great. Thanks for everyone's assistance.
