Introducing the Matrix M-Stage HPA-3U and HPA-3B, review to follow!
Mar 6, 2017 at 8:49 AM Post #241 of 439
canthearyou,
If you still monitor this thread... I checked the specs of the Sparko's Labs SS3602 OpAmps and they call for +/- 18 Vcc Max which is the original voltage in the HPA-3B. That means one wouldn't need to replace the voltage regulators if they wanted to use Sparko's Labs SS3602 OpAmps only. Right? I understand you wanted to "roll" different OpAmps in your HPA-3B.
And based on your one post you ran the Sparkos in unmodified HPA-3B before you modded it. Did you notice any problem? High heat? The Sparkos call for 18V max and absolute maximum of 22V.
You are correct. But I wanted to lower the voltage to allow me to swap to other op-amps. The Bursons are a Max 17v and tend to run a bit hot at that number.
Now I can try any op-amp on the market without worry of overvoltage.
Before the mod the amp ran on the warm side. I know this is due to its class-a topology, but I still wanted it a bit cooler. This led me to install the case fan, which dropped temps dramatically. After I lowered the voltage the amp runs much cooler and negates the purpose of the fan. But I already installed it so now it's gonna stay put.
Mar 9, 2017 at 2:37 PM Post #243 of 439
How do you know? Wouldn't the two huge caps be the power supply ones. 470uF seems too little for power supply. I can see 6 smaller caps on pictures. I think they must be what s/he is talking about. Two of them could be the shunt ones. Don't know what the other 4 do.
It is a worth upgrade, this affect the sound. The sound is better indubitable. A better, refined texture, strooong bass!!, voices are more realistic.
Mar 9, 2017 at 2:40 PM Post #244 of 439
  I would be surprised if this amp had capacitors in the signal path. I am not sure what loserica meant by saying "I replaced the 6th Nichicon caps". Probably just 6, not 6th. Maybe some of them could be the shunt capacitors, given the number is not 2, 4 or 8. I doubt it could affect the sound if those capacitors were not in the signal path (if there are any). But point taken - I can see how it can matter if there are capacitors in the signal path.
I don't have the amp to try the Sparkos. I am only thinking about it.
I replaced all 6 Nichicon capacitors.
Mar 17, 2017 at 1:50 PM Post #245 of 439
Thinking of grabbing the HPA-3U, can someone assure me unlike the HPA-1 it has no problems running IEMS and low impedance headphones, humming etc?
Mar 18, 2017 at 4:40 AM Post #246 of 439
I have a HPA-3u+. I have a $5 iem & I din't hear any hiss with it when I tried it on. My lowest impedance over ear is M50x, which doesn't seem to pick up any noise either.
Apr 19, 2017 at 3:39 PM Post #247 of 439
I just bought a used HPA-3U. All works well, but I get humming on the lowest gain (5db) setting with my T5p headphones. It gets worse when I touch the input or gain selector toggle switches. The other gain settings are fine, and have no humming.
This problem is only with my T5p's, which have an impedance of 32ohms, and with the lowest gain setting. My 600ohm T1's don't have any problem, and neither do any of my other low impedance cans.
All inputs are disconnected, and I've tried swapping cables on the T5p's.
I've heard of humming issues with the HPA-3U, but this is strange. Anybody got any ideas how to fix it?
-Mark.
Apr 23, 2017 at 10:46 AM Post #248 of 439
Try using an isolation transformer to power up your HPA-3U or at least a dedicated ground-loop eliminator device (for mains outlet).
You could also try to shield the inside transformer, but this means a bit of tinkering (http://www.head-fi.org/t/770610/introducing-the-matrix-m-stage-hpa-3u-and-hpa-3b-review-to-follow/45#post_12120336).
Apr 23, 2017 at 6:18 PM Post #249 of 439
Hi. Thanks for the tips. I saw your earlier posts, and I like the mods you have done. I noticed that turning it upside down, can affect the hum or even make it go away completely for a while. So can putting a little pressure on the power connector or phono inputs. All of the screws seem to be tight. I wondered if it could be to do with the toroidal transformer or something being lose.
Apr 24, 2017 at 12:44 AM Post #250 of 439
PCB traces for rear audio plugs from the rear are placed on main PCB, at the bottom of the DAC, so if there's any noise getting in there then it will go straight to the input caps and then to potentiometer. If the hum is not caused by a ground-loop or a noisy earth/ground then you could probably use some sort of shielding between DAC's bottom and main PCB, then connect the shield to the ground. Though, I'm almost sure this is do to a ground-loop or some inside grounding issue that should be double-checked prior to start any DIY tasks, especially if device is still under warranty.
Apr 28, 2017 at 4:03 PM Post #251 of 439
Thanks for the pointers, raoultrifan. I tried a few things and noticed that connecting the phono, USB or headphone output ground to the chassis eliminates the buzz. I also measured that there's 100ohms between the chassis ground and signal ground, which I guess was done to prevent ground loops but in this case it might be causing one, unless there's some other root cause. I bought the amp used on ebay.
Apr 30, 2017 at 6:22 AM Post #252 of 439
Any impressions on matrix quattro amp vs mstage 3b? Im from the Philippines and quattro is still available here. The 3b would be purchased on aliexpress. I would be using it with the hd800. Need help
May 5, 2017 at 6:22 AM Post #253 of 439
I'm still trying to resolve the buzzing issue with my HPA-3U.
I noticed that removing the DAC module make the buzzing go away, so it plays a roll. Perhaps as you said, raoultrifan, adding shielding under the DAC would help.
I also noticed that there are a couple of resistors soldered on the underside of the opamp and sealed with hot glue - Ive added a photo below. Are these original, or a modification? According to the text on the top side of the PCB the revision is 1.6.
May 5, 2017 at 7:06 AM Post #254 of 439
If I'm not mistaken those 2 resistors are 6.04K and they're soldered between both the inverting inputs of the opamp and the V+ from those 2 caps (330uF I guess). Doesn't looks like a Matrix job, but only someone with HPA-3U can confirm that (I own HPA-3B).
O picture from above the opamp might help, just inca se someone did upgraded the default opamp with something else the original resistors from the front of the PCB got burned. We should see some smoked resistors perhaps. Also, if you can measure those 8 resistors it would be great; if you'll find 6.04Kohm on 2 of them then those are burnt (and you're actually measuring the resistors values from the back of the PCB).
Anyway, if amplifier sound great, then maybe you should just ignore those 2 resistors.
If there's a way for you use some protective shielding, without creating short-circuit, it could help in lowering the buzzing sound.
L.E.: Hope I'm right with the resistor's value: https://www.digikey.com/en/resource...version-calculator-resistor-color-code-5-band
May 6, 2017 at 3:59 PM Post #255 of 439
You're right about the resistor values, and they are to pins 2 & 6, so the inverting inputs. Ive attached a photo of both sides of the pcb. I'll test the other resistors later. Could anybody confirm if this is original work, or a modification?
