How do I access it? There is no mechanism to open it. Should I open the device by the 2 screws on the side?Try swapping the fuse with the spare, should be in the compartment next to the iec.
Appreciate the help, man. How do I change the fuse though? Do I have to open the device? Does that not void the warranty?you should be able to pry it open with a thin object.![]()
Do not unscrew anything, you simply have to pry open the fuse compartment beside the outlet, there should be a spare fuse, swap them around.Appreciate the help, man. How do I change the fuse though? Do I have to open the device? Does that not void the warranty?
I did it. It finally works. You are a lifesaver, my friend. Almost send it back to Amazon. Now im testing it out. Again, thank you!Do not unscrew anything, you simply have to pry open the fuse compartment beside the outlet, there should be a spare fuse, swap them around.
Outside (top) oneI did it. It finally works. You are a lifesaver, my friend. Almost send it back to Amazon. Now im testing it out. Again, thank you!
Edit: One last question though. Which fuse is in usage now? The one inside the chamber or the one tucked on the outside?
Ef600 and serenade are extremely smooth.No way. The ESS Sabre Smsl M500 mk1 with Ananda Nano is tiring me in terms of fatigue very soon. I heard very favourably of Hifiman's dac and amps. Is EF600 very wide, big bold bass, non-fatiguing sound, I heard?
I wonder which is more of this compared to the Serenade.
