animaal
- Jun 3, 2005
Up to now, I've never really believed that there was any logic behind the theory that cables could make a difference to sound quality.
Tonight, I was reading an article about how badly designed HDMI is. (What's the matter with HDMI).
Although the article does not focus on audio cables, it makes sense that much of it would be relevent to audio cables. This may be old news to everybody, but just in case anybody finds it as interesting as I did...
There are a few considerations that start to cause real trouble: Time: electricity doesn't travel instantaneously. It travels at something approaching the speed of light, and exactly how fast it travels depends upon the insulating material surrounding the wire. As the composition and density of that insulation changes from point to point along the wire, the speed of travel changes. Resistance: electricity burns up in wire and turns into heat. Skin effect: higher frequencies travel primarily on the outside of a wire, while lower frequencies use more of the wire's depth; this means that higher frequencies face more resistance, and are burned up more rapidly, than lower frequencies. Capacitance: some of the energy of the signal gets stored in the wire by a principle known as "capacitance," rather than being delivered immediately to the destination. This smears out the signal relative to time, making changes in voltage appear less sudden at the far end of the wire than they were at the source. This phenomenon is frequency-dependent, with higher frequencies being more strongly affected. Impedance: if the characteristic impedance of the cable doesn't match the impedance of the source and load circuits, the impedance mismatch will cause portions of the signal to be reflected back and forth in the cable. The same is true for variations in impedance from point to point within the cable. Crosstalk: when signals are run in parallel over a distance, the signal in one wire will induce a similar signal in another, causing interference. Inductance: just as capacitance smears out changes in voltage, inductance--the relationship between a current flow and an induced electromagnetic field around that flow--smears out changes in the rate of current flow over time. Impedance, in particular, becomes a really important concern any time the cable length is more than about a quarter of the signal wavelength, and becomes increasingly important as the cable length becomes a greater and greater multiple of that wavelength. |
