edesilva
- Jan 11, 2005
Glad I found this place... I'm in the process of ripping over 1000 CDs in WAV format for a media PC (I am using EAC, had huge problems before with other rippers). Right now I'm thinking in terms of buying a media PC--probably the Niveus Denali--b/c I've got no idea how to build my own, and the Niveus seems really quiet. I think the WAVs will get stored on one of the new Buffalo terabyte NAS servers with RAID 5 when the become available next month. Here's my question...
I'm really *only* into 2 channel audio. I've got a stereo with a high end upsampler and DAC--the dCS Purcell/Delius combo, and want the highest quality PCM out--no DTS/Dolby/multichannel. In another room, I'm currently using a USB audio device--the Edirol UA-1D--into a Theta Pro Basic IIIA DAC and it sounds pretty good. The Niveus literature doesn't indicate anything about a sound card in the Denali, just that it has "Intel 8 channel high resolution 24/196 kHz audio out." I *think*, but I'm not sure, that means the audio is on the MoBo. My question is whether (if I'm right) there is any problem with trying to run PCM audio out through a USB port? Anyone know if there are compatibility issues?
Anyone have any familiarity with the Intel 8 ch audio? Since I only care about 2 ch, any idea of its quality for that application? If I watch a DVD, anyone know if the Win MCE software will allow conversion of DTS/Dolby material to 2 ch PCM?
In this vein, I've already got a CATV box hooked up to my stereo. Problem is that the CATV box only has Dolby/DTS on the coax out. My totally kludgey solution is to run the analog outputs to an ART DI/O and then the digital out from that into my Purcell--but that is an A2D2A2D2A conversion. Is there any small/cheap box out there that will simply do digital to digital conversion of multichannel DTS/Dolby into PCM? If I get a media PC, do my options increase? I.e., could I run the digital from the CATV into the PC, do a software conversion to PCM, and use that? Any idea what software would be useful in that respect?
Any help/ideas appreciated...
