DPM
- Sep 21, 2001
I'm about to install an Emu 0404 but would like to keep my current sound card. Is it absolutely necessary to remove the drivers of the current card and then reinstall it after the Emu card is running as suggested in the instructions? Or could I just disable the first card while installing the Emu card?. Or perhaps I can just install the Emu card as is. I believe the current card I have is a Soundmax card.
thanks
thanks
