Originally Posted by adhoc the ra-1 curse strikes again!
Sorry I am a newbie on the forum. What is the RA-1 curse?
When I opened my own Benchmark DAC1, I was pretty amazed to see NE5532 OPAMPS. Aren't these the cheap BJT OP amps scorned by many DIY school audiophiles. How come the unit sound so good to my ears? Can the sound be improved by further tweaking? Or maybe the designer found a circuit layout that makes NE5532 sound good. I guess, if expensive internal components is the sole road to audio nirvana, there would not be so many things to discuss about audio electronics in the first place.
I hope during the summer I will have the chance go to a friend's place and A/B test DAC1 against his Mark Levinson CD player. I will post my findings then.
The RA-1 amp also sounds good even though it costs a lot and has a real cheap opamp in it.
I decided to listen to the DAC1 with my RME Digi96/8 PAD, Sonica, Pioneer 563A, and Toshiba SD-3950. It does sound good on all of them. A couple of things I notice is the clock crystal is 28.322 mHz instead of a common 24.576 mHz. The other thing is the increased power over the normal Buf634 buffer that I am used to. That is because instead of the typical +/- 15 volts, they put the absolute maximum rated voltage on it of +/- 18 volts. It's also wired for full bandwidth mode.
Proved that despite its huge size the CD3000 can be shoved down one's throat.
Originally Posted by intlplby the pic is too small to work from
anyone want to study the board and post a schematic so we can make a benchmark DAC 24/192 clone
Maybe if you contact them they will send you the schematic to you, I had pretty luck with a lot of manufacturers to the date, even Sony, most of them would send you a copy without problems....They don't care of one man doing a clone for personal use, the selling of clones, is what they would not like....
Both the Benchmark DAC1 and the Bel Canto DAC2 use the AD1896 async sample rate converter. The evaluation board for the AD1896 is only $167 and includes a Toslink and coax input, S/PDIF receiver, DAC, and opamps. Just add a power supply and you have a close one.
Originally Posted by dip16dac Both the Benchmark DAC1 and the Bel Canto DAC2 use the AD1896 async sample rate converter. The evaluation board for the AD1896 is only $167 and includes a Toslink and coax input, S/PDIF receiver, DAC, and opamps. Just add a power supply and you have a close one.
I have looked at this and want to order one, is stating a buisiness in the registration needed to get the evaluation board or can anyone obtain one?.
Anyone can start their own business. You can put your nick or what your company name will be. It shouldn't be a problem. You'll be evaluating it for Head-Fi.
