phkd
- Mar 5, 2004
I want to get a new pair of headphones but there is so much out there and i keep finding more and more options. first i was going to get grado 225's, then i found out about the allesandro ms-2's and decided on those. then i got ety ER4S's and returned them after realizing the in-ear thing was not for me. then i looked into those stax e-static systems, and realized the only ones i could afford weren't worth getting. then i started hearing a lot of good things about the senn 580s and the beyer DT880s. as you may be able to tell im trying to not spend more than $350. this would be so much easier if there was a good headphone store around where i could try all this **** out (is there anything like that? around massachusetts?).
well what do you guys think? best open air's for under $350? (if it helps, i listen to rock/rap/electronic music through my chaintech soundcard or rio discman. i will get an amp after i get some new headphones. one chaotic decision at a time).
thank you thank you thank you
-aj
-aj
