Jul 15, 2012 at 11:05 AM Thread Starter Post #1 of 17
NAeternal
Hey, i use 32 ohm sennheiser hd407 and creative x-fi go pro sound card. (i dont know the soundcard's impedance, if you find it i'd be very grateful)
I was having buzzing at bass, so i decided to make a 100 ohm adapter cable. It worked to fix the buzz, but cut the volume down like %50. So, is there any way to increase volume, besides amplifiers?
If i make a 50 ohm cable instead of 100 ohm, will it work too with the equipment which i said up there?
Jul 15, 2012 at 12:18 PM Post #2 of 17
Are you listening at a fairly high volume?
You may be running out of power?
The 50 ohm resistor will still decrease the volume somewhat.
Jul 15, 2012 at 8:15 PM Post #5 of 17
Sorry man, if you really want to increase the volume (assuming you need more power) you need to buy an amp.
Is your X-Fi a little USB key with a headphone jack?
Jul 16, 2012 at 4:50 AM Post #6 of 17
yes it is, but without the resistance imported, the volume level is great. (i mean the direct connection with headphone's jack, sound card's output)
it is just the addition of the resistance (100 ohm), cut down the volume like %50.
i was wondering, if i'd use 50 ohm resistance cable, instead of 100. would it be still the same? if not how much volume gain i'd get, compared to 100 ohm ones.
edit: well, i find out there are no 50 ohm resistors, so let's say 47 ohm or 56 ohm. doesn't matter actually, you got the idea.
Jul 16, 2012 at 6:56 AM Post #7 of 17
Yes, with 47 or 56 ohm you will loose a lot of volume.
Jul 16, 2012 at 7:06 AM Post #8 of 17
(Voltage Squared)/Resistance = Power.  An impedance of 132 ohms will receive about 24% as much power.  That's about -6.2 decibels (65% perceived volume).  To achieve a perceived 50% volume, 10 decibels must be lost, which would require a cable with 288 ohms (10x the resistance, or 1/10th power).  A 50 ohm cable will put you at -4dB (76% perceived volume).
Jul 16, 2012 at 9:10 AM Post #9 of 17
Well, iZMXi that was the answer which i needed, thank you so much.
So, is there any solution to boost the volume up, besides amps cause they are kind of expensive in my country
Another question
would a fiio e5 (in example) make the perceived volume up from %65 to like %90 or something?
Jul 16, 2012 at 10:55 AM Post #10 of 17
That is not entirely correct, since it is the power into the headphones that matters, the rest just heats the resistor. Therefore, the real volume reduction is 20 * log10(32 / 132) = -12.3 dB.
Jul 16, 2012 at 5:06 PM Post #11 of 17
Well, that means 4.5 db difference between 47 ohm and 100 ohm resistor, still not that good?
Actually my headphone vol is good @ %100, but it is the feeling of "i can't increase the volume more" that bothers me.
Lets hope 79 ohm (-7,84954226 db) is gonna be enough for me, and still fix the buzzing ofc.
one last question for me and the people that want an enlightenment for this matter
my current resistor is 100 ohm 11 watt, if it was 100 ohm 2 watt, would be there volume increase (more power to the headphones)?
Jul 16, 2012 at 9:29 PM Post #12 of 17
No way.
They are both still 100 ohm resistors. Sorry!
In your case, it is the resistor's value that is of significance. Not the resistor's power rating (it's Watt rating).
Headphone amps usually only output a few thousandths of a Watt,  i.e. much less than one Watt.
If you can't increase the volume any more with zero resistance, adding more resistance will only make things worse.
Sounds like you need an amp.
Jul 17, 2012 at 12:00 PM Post #13 of 17
Well, i bought a 47 ohm 2 watt resistor today
Removed the 100 ohm one and imported 47 one, it means -7.8 db decrease in volume. [20*log10(32/79)]
So i added +7.8 db from soundcard driver's equalizer. Same volume output as the zero resistance, with no distortion. Fixed the buzzing at the bass problem that happens with zero resistance too.
Win!
Jul 17, 2012 at 12:17 PM Post #14 of 17
well you will get distortion, maybe you just cant hear it, or havent come across any tunes yet that are hot enough that your increase in level digitally clips the onboard amps input. your USB thingo is limited to the voltage USB can supply, which is a rather paltry 5v
