killerline
Heya guys!
To begin with, sorry if I started this in the wrong section or perhaps even forum. But I love both you guys and your expertise so this would be an acceptable exception. c:
Okey so in this instance I've hooked up my PC to my receiver by HDMI. But I was thinking, even a Xonar Essence STX II (as I happen to own one for my DT990) should improve the sound quality further than it is now, right? The receiver's a Pioneer VSX-922 and my GPU a GTX 1070 if that is necessary.
So my question for you is should I stay this way with the HDMI cable or should I connect it through RCA/ Optical from the STX II to the receiver's audio in? What would be the best choice?
And if you know of any other way that you think is better than I'd be pleased to hear about it. Oh, and I'm unfortunately unable to spend money over like 30 bucks 'cause this setup was an expensive one
. Running 2.1 for those who're wondering.
Cheers
Cheers
