NellieG
Is it risky for the headphones or is the higher available wattage ok as long as the volume is kept in check?
It's fine. Keep the volume in check, they can handle more than you can take and your not using all the power available. I use a 6 watts per channel THX 789 amplifier but I'm not actually using anywhere near 6 watts.
Think of amp power like a car. Would you rather drive sat at 80 miles an hour with a 1 litre engine or a 3 litre. Power is dynamics and control, you have more headroom available. Imagine driving at 80 and then wanting to overtake something, you need that big engine again to quickly pick up speed.
Voltage is volume like horse power is high speed.
Amps is control to quickly control the drivers like torque is what gets a car moving.
Neither car or speakers need high power to make them go but both are way better with more power, even if we don't use it all all the time.
