- Aug 18, 2007
The EF2 DAC uses the Burr Brown PCM2702E Japan DAC chip and seems better than a typical iPod line out or PC/Mac line out, is on the level of the 3MOVE DAC or Predator or Travagans White and Green, and below the Pico USB up-sampling DAC or the Apogee Duet or Mini-DAC. I haven't heard the 0404 or Bithead to compare. In my reviews I have found the PCM2706 based DACs to not be quite as good.
I believe Hotaudio makes only one DAC that should theoretically be on the same level, using the same Burr Brown PCM2702E Japan DAC chip. But, circuits make a difference in sound too, and the same DAC chip can still mean different sounding DACs at the line-out.
Originally Posted by Zertman /img/forum/go_quote.gif Thanks again everyone. Wow! I guess there are a lot of options out there. I'm a little overwhelmed. Those Hotaudios look good, though the amp seems a little weak. They probably would be strong enough for my 265HDs but I would like someday to upgrade my cans and they probably would have much higher impedance. Levin, The PC I using in with my cans is a laptop so I need something external. Plus, I want something with a headphone amp built-in. The Hifiman EF2 look good and very powerful output. I read your review of this, HeadphoneAddict and I am little worried about how the DAC sounds. You said that it lacked soundstage which is a quality I value very high in my cans. How does the DAC's of the EF2 sound compare to the Total Bitheads, emu 0404, or Travagans Green (or White). |
