Jonnibravo
- Sep 3, 2013
Hi all can anybody recommend a portable headphone amp that will improve the sound of my S10+ budget is £100 maybe 150 at a push.
Maybe whenever Topping starts using USB-C. lol jkMake sure it’s the NX4 DSD
My argument for the BTR5 is that it can be used as a USB-C dac/amp with the added benefit of bluetooth. It's probably a bit brighter sounding than the NX4. What's impressed me with the BTR5 is what it can drive as well as the app functionality.
If you do go the NX4 route make sure you buy a Micro-USB to USB-C cable if you want to use it in DSD. I'm pretty sure the NX4 doesn't have one included, but I honestly can't remember. I know I have this cable and it works well:
https://tinyurl.com/tz8h7s3
I'd like to add the only benefit you will gain by using the NX4 DSD is if you have lossless audio files on your phone. The NX4 is a good porta DAC/AMP, but I mentioned the NX2S because it's cheaper with longer playback time but it doesn't have DSD. If you want to go down that route I'd say it's between the NX4 and FiiO Q1 Mark II. You will also need the micro-usb adapter I linked above.
https://tinyurl.com/yx246dpr
Good luck!
I do have a few probably better alternatives if you're more concerned about improving actual audio quality. There’s the FiiO K3, it is not battery powered but I have had good luck using the S10+ with it, basically you’d just run it usb-c to usb-c.
