jaddie
Account deactivated by request.
- Mar 28, 2011
I would still install the drivers and check it all out. You're suffering from low output, right? The thing has the capability of pushing your headphones to a respectable volume, but it isn't. It would cost you nothing to run the control software and see what's up, make sure there's no hidden volume controls holding it back.
But perhaps you'd rather just replace it, which is cool too.
Well the -6db function should be native to the VRM software which I never installed. It SHOULD just be the cirrus logic chips working as a plug and play device without any proprietary settings.
my curiosity got the better of me - without the vrm drivers, it's +0 by default.
