- Apr 12, 2004
I picked up these interconnects from Audiogon several weeks ago as a trial run to explore some other silver IC options. (Wasn't sure if I was going to keep them.)
Now the main reason I strayed from my Signal Cable ICs (Silver Res Analog) is because I finally got tired of the Eichmann bullet connectors (royal PITA to deal with) and wanted to get some ICs that used a different RCA connector. These ICs use a WBT-style locking connector.
That said, these ICs are awesome. I got them on the strength of a recommendation here by Jon L, ownership by another Head-Fier, and a positive review on 10audio.com. (No feelings about PS Audio, I know there are plenty of people in the audiophile community who have a few things against the company.) I'll start with the cons though:
- Partially inflexible. Argh. You can easily bend them, but they're not "loose" flexible like my Signal Cable ICs are. In other words, they don't shake around much when you hold them up in the air.
- They're pretty thick. Kind of annoying to me. I like how thin the Signal Cables are. Of course this is most of the cause of their partial inflexibility.
- The locking connectors are also pretty annoying to deal with, as they don't turn very smoothly, and there are lots of spirals so lots of turning is needed.
Those cons aside, the biggest praise I can give these cables is that the improvement in sound is practically on the scale of an amp or source upgrade. As soon as I stuck these on between my Gilmore Lite and Arcam CD33, that was my immediate thought - I felt as if I had a brand new amp or source! I was bowled over, and for the first time I really felt like I was truly hearing both the Arcam and the GL. These also definitely burned in - I'd gotten them in new still-shrinkwrapped condition so I started at 0 hours (initially impressive), and then burned them in for 200 hours to find out what would happen. While they did start out impressing me, they got even better - transients sped up (initially it was kinda slow), and the bass cleared up too. Initially not completely clear, but it developed into a hard-hitting, wham-arific bass. The tactility and slam definitely improved from the initial state. And soundstage opened up too - initially a bit small, but as time passed it expanded and became very 3D.
All my previous conceptions of the Signal Cable ICs really just went out the window. I used to think they were great cables. Now I just think of them as great values. The PS Audio absolutely lives up to its name, it's transcendent over the Signal Cable - the soundstage opened up with even more depth and width, an entire veil over the mid-bass and lower bass was removed making everything sound so much more realistic, and attack/transients are SO much clearer I can't believe I got by with the Signal Cables. Percussion strikes are actually complete now. Treble too is much cleaner, much faster, and extension so much more audible.
For $350 new, these are some really great ICs, and I have to echo the positive comments and reviews. The SQ is amazing, and $350 isn't too bad of a price, and yes they do sound very silver. Physically though, I don't like them, and that's the only reason I won't be sticking with these much longer.
