Rameish
- Jun 22, 2001
Ebonyks,
I can confirm that tha Beyer DT-931 has become a favourite of mine with a Corda HA-2 (120 ohm) jack. The Corda HA-2 is a touch warm and the Beyer DT-931 is a touch bright so at the 120 ohm jack it is a very nice balance.
Frankly having heard the DT-880 (yes I do own one as well), I prefer the DT-931.
As for the stock Senn Hd-600, it's quite nice with classical and for classical I actually prefer the HD-600 over the DT-880.
However, for rock and pop I prefer the DT-880 over the HD-600 (but I still prefer the DT-931 over the DT-880 and prefer Grado RS-1 or even the SR-225 over the DT-931 for heavy metal and rock. The speed of the Grado's is second to none.
Of course the Grado HP-1 are fare more refined if you can tolerate the weight on your head and it actually has less resolution than the Grado RS-1.
Getting back to the point, if you only can send money on one headphone the DT-931 may be the ticket if you have slightly warm sounding amp. Hover if your amp is on the bright side of things then the DT-880 or even the Senn HD-600 might be better bets.
It's all down to system synergy - plase also consider if your CDP is warm sounding or bringht sounding. Minor errors can be fixed by cables etc.
I always like to start from a high rez standpoint andwork my way to get the soundstage etc.
The DT-931 has very nice air/atmosphere as well.
