thuNDa
- Apr 29, 2016
Hello @TheGiantHogweed
Thank you for your review. Any chance you could take close-ups of the pcb inside? Specifically, it would help the community to know how the thing is built internally. It would be nice to have close-up pictures of the chips on the PCB. There does not seem to be much information about the amplifier section on this amp. It does state it uses the following chips.
- Digital Receiver : DIR9001
- DAC Chip : PCM1793
- OPA2134 and WIMA caps
I am guessing the OPA2134 opamps are used for amplification but is that all they use? Any pics of the internals would be very helpful if you could share them..
Another thing to note about the specs for this amp: Earphone output power: 65mW @ 16Ω; 130mW @ 32Ω
They make no sense, the output increases from 65mW@16ohm to 130mW@32ohm? Output should typically halve when impedance load is doubled..
I am looking forward to seeing if this amp can power my Fostex T20v2 cans.. I might order one just to test it out...
I made a pic of the PCB:
The HP driver chip is actually a Maxim max97220(close to the white caps at the poti, which you can't read on the pic tho).
Other observations i made, are that the Opamp runs at +/-5V(they gained one Volt with some diode trick close to the biggest cap), and that the bass rolloff could be improved with larger caps (again the ones at the poti, which are rated 1uF - i would go for 2.2uF - had some small cap soldered in parallel to one of them and compared the frequency response of both channels).
Originally It's down 1.8dB at 20hz, and 0.7dB at 30hz(tested with RMAA).
