tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Honestly, I just wanted to build an amp. They all cost about the same amount....
So what if I chose a 3 channel? Literally, so what? It still sounds good, right? There are still people who have built it and love it, right? If there are any issues or problems, I also am building the o2 amp...
If there are further and further issues, I now have MULTIPLE opamps I can use for future builds.
There's a very easy way to tell when you build one. Simply temporarily short the output ground channel to chassis ground. You can do this by simply connecting the headphone jack's ground to chassis ground. That will take the active ground channel out of the circuit. The difference in the sound of the amp is night and day. It's one of the things you must do when building one - be certain the output ground is isolated from the chassis ground for proper operation of the 3rd channel.
It's also a reason why many people don't know how to properly test one - you have to lift the ground on the measuring device, or else you're shorting out the active ground channel. There's been a whole lot of mis-informed scuttlebutt spread around the internet as a result - and that's probably an understatement.
From Morsel's webpage on the PPA (the original active ground channel headphone amplifier):
"Signal ground is input ground, not output ground. Output ground is the output of the ground channel. It exists solely to drive headphones. It is not a true ground. Do not connect signal ground to output ground. This defeats the purpose of differential output and may cause amplifier instability. Do not use the headphone output as a line level output as this may short signal ground to output ground. Use signal ground instead of output ground for line level outputs."
http://elvencraft.com/ppa/
It's easy to see that without proper precautions, testing the output on an active ground channel amplifier can lead to horrible measurements if the instrument is connected in the "normal" way, as if the amplifier was a line-level device from the headphone jack.
So yeah - build a 3-channel amplifier ... they definitely sound good.
