remilard
- Jun 9, 2004
So circumstances occured which required the reinstallation of windows on my computer. When I would turn on the computer, I would get a text screen that said something to the effect of "Windows did not start normally on the previous attempt......."
and then let me choose between starting windows normally and three flavors of safe mode, none of these worked, but this isn't the problem.
So, I get out my IBM product recover CDs, which are not a typical windows installation CD, but are designed to install windows and all the other software that came on my computer originally.
So, the recovery cd's do there things, presumably formatting the drive and copying some things, I put in all four, things look great, and then after the fourth cd is restarts the computer, presumably to finish with the installation.
But when the computer starts, the screen I described above comes up. So its like this thing is jumping in and preventing the IBM recovery program from finishing.
Windows XP home is the windows version in question, and I have an IBM bios (their appears to be minimal variation in versions of the IBM bios but it is a 2002 version).
So how do I get past this? Is it the bios that is doing this or something in the MBR? If it is the later, I have a new hard drive (samsung spinpoint) on they way anyway, so I would just wait for that and start over. If it is the bios, the new hard drive isn't going to help so I would have no idea what to do to get past that screen and finish the recovery process.
Any ideas?
Any ideas?
